does anyone read these
spiked
I have two questions if anyone can answer them. <br />1. If the rectifier goes bad can I fry the electronics?<br />2.If I remove the timer base do I have to "re-adjust it", if yes than how?
rodbolt
Re: does anyone read these
not usually but its possible, and as long as you dont mess with the link rod adustment it will fall back in place. but now 2 questions for you. what "electronics" do ya think are fried and why are you removing the timer assy ?
spiked
My friend had an extra timer base and stator off a motor he no longer has but we knew it worked so for the hell of it I threw it on to see if it changed anything.<br />Three out my four coils are not firing and when I was cruising at speed my volt meter was well above 14 volts, somewhere like 16-17. I thought that maybe if its overcharging it could have fried some of my electronics. I don't know. I took my only good coil and made sure both power packs would fire it off therefore eliminating my powerpacks,(atleast I think so)<br />I read in a tech section of outboardparts.com that if the rectifier is bad it would give me similar problems that i'm getting.<br />Why would 3 coils just go bad and one wouldn't?
