Re: Does fiberglass rot or become brittle
Well does it? Reason I ask is because I have his premonition that my swim ladder is going to rip out of the hull. I'm pushing 210 I have a friend that is around 240 and maybe some other larger family members once in awhile. I already lengthened the screws and put some wood on the back inside to reinforce it. Am I overreacting or is this a legit possibility?
Yes .. Fiberglass can indeed "rot" per say.
Freezing can seriously damage fiberglass when moist and not properly resin coated. I have seen Fiberglass just completely Mushed.
If you can reach the inside with a new wood .. then Through Bolt that swim ladder with some fender washers.
As far as how 'sound' your mounting points are .. you have to determine that.
But no..your not overreacting .. its completely lagit.
Gelcoat UV thing does not apply here when we are talking about Fiberglass.
Yes the FG will break down over some serious time .. but its not like your boat is built out of marshmellows ..its not going to melt away over a few seasons
Hope this helps
YD.
