Does Gelcoat add any more protection over Epoxy?
Luhrs28
I've done the inside work patching over a bunch of defunct thru-hull holes on my old Luhrs and I'm about to start on the outside of those same areas. What I'm wondering is, can I just do the Epoxy/biax, let cure, sand smooth and slap on the bottom paint? Or does the Gelcoat really add another level of protection?
If the Gelcoat is really only for a sleek-n-shiny appearance I might skip it since nobody but me is going to see the bottom before I paint it.
Thanks,
Bert
Kiwifisher
Re: Does Gelcoat add any more protection over Epoxy?
Gelcoat does not adhere to epoxy so just sand smooth and paint.
ghamby
Gel-coat resists UV, epoxy doesn't.
Yacht Dr.
I would put a few coats of just epoxy after your fairing work before you bottom paint to seal it. Prep your epoxy for paint of cource :) .
YD.
Luhrs28
OK very good. Thanks for the replies.
Bert
