Re: Does it charge?
Dave, If you trace the two yellow stator wires from the flywheel, down the starboard side of the block they will connect to the full wave rectifier. Run the motor and put a volt meter on the battery. When you rev the motor, the voltage should rise a bit. If not, you will need to check the rectifier for proper operation.
