Does my '57 Johnson 35 have a fuel pump?
adt2
I'm looking through the replacement fuel pump offerings here on iboats.com, but I can't find one for my 1957 Johnson 35. I'm pretty sure my motor uses fuel...
jbcurt00
A 1957 Johnson uses a twin line fuel hose to pressirize the the tank and force fuel into the motor.
Unless its had a pump added, it doesnt have one.
If ones been added, you should replace it w the same pump
Very common mod to swap to a fuel pump and run single line fuel hose
adt2
Mine's had one added, then. I use a single fuel line. I'll check it and order one similar.
Thanks
