Re: Does my engine have a batt charger?
....but to check if it is charging properly or not, with motor off, measure DC voltage across battery terminals, should be about 12.6 volts<br /><br />with motor running, do same and should be higher, over 13 volts<br /><br />if it gets lower with motor running, you need a new rectifier
