I have 2004 or 5 F115 with original SS prop. Does this have the hub with rubber shock? i run in some pretty shallow water and have really beaten up the skeg. Wouldn't shock hub give me best protection?
thanks
You might also be better off using an aluminium prop; a stainless steel prop being so much stronger might cause damage to the engine if you continually hit the bottom. Cheaper to replace alu props then crank shafts.
