Re: Does my honda 7.5 have an alternator?
You may have a plug that is just a cover for the recepticle, you will probably have to get one that has prongs that you can connect wires to. You should be able to find it at the dealer, or here on iboats, that is where I get most of my parts. Also I have heard it both way on the battery. You may get away with plugging in very small electronics to the plug, i think they only have like 1-2Amp output. So you might have to hook up a small 12V battery, hook you electronics to that, and then use the motor to charge the battery. If you run that battery dead while sitting with the motor off, you may have a long way to go to recharge it. I would suggest charging the battery out of the boat with a battery charger during the week, and then putting it in the boat, and use the motor to maintain it during your boat outings on the weekends.
