Valley Boater
- Joined
- Oct 1, 2009
- 80
In process of first lower unit repair and this is the first lower unit I've seen up close and personal. Looks like a previous repair was made to build up the water pump base (photos attached). When plate is installed, it looks like a flat fit. The "inlet" gap is the plate looks unblocked when the plate sits on the rebuild.
Does this look reasonable to continue to install a water pump kit (on order) or should I possibly look for another lower unit? This lower unit has obviously been in salt water and it took me about 2 hours to chip out the salt & oxide crude from the front cavity and finally I have water draining out the forward hole.
Proceed with this unit or should I look for a more promising lower unit?
The support group has been so helpful so far. Perhaps this old '79 will see the water again.
Don
Don
