Does this look like a slipping prop?
archcycle
1990 140hp johnson / 16' cape horn deep v
Do these pics look like this prop is slipping? The pictures are of a loaner from a local shop after running it saturday and sunday. My current prop is 15x17 and in rough water or when heavily loaded I'm maxing out at 5k but with a light load in flat water it planes out to 5500+. Shop guy loaned me this 15x15 (shop tuned measurements) to try out. The boat really seemed to like it at the lower RPMs but I got some really diminishing returns as it went up.
Running 4000rpm under a heavy load in ok water it went a steady 26mph, and turning 5600 WOT it bumped up to a max speed of 31mph. 40% increase in engine rpm only resulted in a 19% increase in speed.. something seems wrong there.
The balled up stuff on the forward side of the prop seems to be rubber from the hub.
QC
Re: Does this look like a slipping prop?
Moving to the Prop section. Good luck!!
Ayuh,... There's no way to tell by lookin' at yer pictures,...
Scribe, or paint a line across it, 'n run it, then look at the line to see if it moved...
