Thank you
Are you sure? I was told is was corrision due to water in cylinder.
Because it had water in one cylinder.
No. All the other cylinder are honed though.
You put a new "cylinder wall" in and then you bore in that one to the same size as before. Crystal clear?![]()
Sorry guys, but I've seen plenty of detonated pistons, and that certainly does not look detonated. A detonated piston doesn't even look like a piston anymore. That piston has very discernible valve recesses and the ring lands look in perfect condition. As the OP suggested, I think it's just a little water damage. But, I would like to see the rest of the piston crown before jumping to an solid conclusions. And sleeving is what we'd do here too...
Chris....
I would run it, the ring lands look fine. If the skirt is not out of spec. I know boats are not cars, but thats a usable piston
