I had my boat out yesterday 96' 350 2bbl, alpha one. Had a hard time starting it, but once I got it running it ran great. Towards the end of the day I was cruising and it just shut down, turned the key to start it and it sounded like it was locked up. Wait a few minutes, try again, and it started and sounded fine. Put it in gear and took off, only ran about another 5 minutes and it shut down again, this time I was able to hear something, a pretty loud "tink" or something as I was able to hear it over the engine noise. Again, I turned the key and it seemed like the engine was locked up, and that is how I finished the day and got towed in. Oil pressure was good, engine temp was good. Looking at it this morning there is a wet spot of oil that looks like it's coming from the bottom of the outdrive at the plug, the outdrive oil was serviced 3 years ago along with a new gimbal bearing, drive shaft seals, and whatever else was done, the boat was used once after that and went into storage, so, really this is it's second voyage out after the service was done.
Where do I start?
Thanks again,
Where do I start?
Thanks again,
