The inner bearing disintegrated causing the hub to ride on the spindle. the portion of the spindle where the bearings ride on is not damaged but you can see on the shoulder where the inner bearing seats is slightly damaged. I can knock that off with a file. Does this spindle look ok to reuse by polishing it up with emory cloth and a file? I'd rather not buy a new axle if I don't have to.
