I've been looking through the threads. It seems the u-joint on an SP-A requires pulling the yoke, it seems there isn't clearance to get the inside caps past the bearing box. Last time I worked on an upper gear box for bearing replacement, I recall having to replace a crush ring and shim properly as part of the bearing pretension. If I'm just popping out the yoke so I can do the joints and then bolting back in the same one, do I have to mess with any of that this time? Or can I just leave the bearing box assembled and count on the tension still being ok? Seems like I might be counting on a seal being ok here too, but I can't remember, didn't take pictures the last time, and the exploded drawings in the manual don't paint a complete picture in my mind. Thanks in advance for any advice.
