Don S. please help
Scottaye
I have a volvo penta aq 125b/ 270. Prop wouldn't engage, but would turn slowly when shifted from forward - reverse. I've checked the upper and lower shafts like you said and found out that the shaft from the engine has come away from the engine. I've tried to push shaft back toward engine and it aligns. When I reinstall gearbox on lower unit, it pulls back out of the engine. How far should the splines come through slip joint towards the double cardin u joint? If thats what I'm looking at. I have no repair manual or the means to get one. HELP
Don S
Re: Don S. please help
Assuming you are talking about the shaft in the engine flywheel housing, if that shaft comes sliding out easily, then you proably need a new flywheel housing. The bearing should be pressed in the housing and than a snap ring holds it in place. I have seen, on several occasions, water get in the bellows and into that bearing, the bearing sieze up and spin in the housing and destroy the housing.
Also, in the future, if you have a problem, just put your problem in the title, don't just call on me specificially. This is a forum for everyone.
