New gimbal. Ujoints, stub shaft, lower carrier, new prop and hub, and I still get noise when outdrive is all the way down, and all the way up. Noise is better mid trim, but is audible when turning. Any suggestions?
Yes that would help. '93 glastron ssv 175 4.3 alpha one gen2.
Noise has been present since I bought the boat 4 years ago. It had water in bellows over winter so that made me change the gimbal and joints. Later the drive was pulled and oil was present in bellows so stub shaft and seal was replaced. Lower carrier was done since the water got in there as well and made a mess of the bearings.
Yes that's the shaft I meant. No top bearigs were done. The lower carrier comes with bearings I'm assuming, so yes those were done. Engine alignment has always been hood, and drive oil is good.
