DonS. how does Key Start work?
ANDREW SMITH
Don S, my brand new 3.0L has "key start" that does not work. My Dealer and Mercruiser are working thru this problem but as of today have no solution, so I thought I would investigate further and maybe find a loose wire or something simple. Here's what I see.. There is a solenoid at the carburetor with 44 ohms of resistance that probably makes the mixture rich (like a choke) when the engine is cold. The solenoid has a red hot wire and a black/yellow wire connected to a sender at the t-stat housing. The sender is open when the engine is cold. The t-stat housing has two other senders, probably the overheat and the temperature guage sender. That is as far as I can go. Any help with with this would be greatly appreciated.
ANDREW SMITH
Re: DonS. how does Key Start work?
bump...just looked at the flame arrester, the correct term is "Turn Key Start" the latest and greatest from Mercruiser...Thanks for your help..
Don S
Have never seen one, not much I could say that would help you.
