Don,<br /><br />I was rereading your winterization steps, over at Bayliner forums. Very good info and refresher, even though I am getting ready for the de-winterizing process. It did generate some questions, that I couldn't answer via the Merc manuals. (sorry, I need to find my userid and password for that site!)<br /><br />
My U-joints are smooth, but when I looked up the lube procedure in the Merc manual, it only discusses a U-joint tear down and lube. I assume that it is because I have an Alpha 1, GenII, with permalube bearings. Do those plugs just pull out? Are there threads in the U-joint, once plug is removed, that some size zirk can be installed? or is there another process to lube them? If it means any drilling or tapping, would require a tear down. I would like to lube them, but not have to take them all apart.6. Check the gimbal bearing. Does it turn smooth? if not replace it. Check the u-joints do they feel smooth also? Any catches indicates they are worn and should be replaced. If ok, grease the zirks or pull the plugs (if equipped) and lube them. <br />
