hello<br /> dude I got one that is stumping me. in a bit I will remove the upper case to inspect I am just gathering ideas on a problem I have never seen. unit is a 1999 alpha 1 gen II with 3.0 power. while installing new pumpkits I noticed drive oildraining from both exhaust idle relief ports. ever seen that one. as soon as I get motivated I will remove the upper drive. I suspect the yoke isleaking and draining past the bellows sealand entering the exhaust cavity through a bad shifter shaft seal. ever seen drive oil drain from the exhaust reliefs ?
