Re: dont know to much about boat motors help
If your engine has sat for 10 years, you must replace the water pump impeller. Obtain a manual before attempting this.<br /><br />You will see the difference when you get a new impeller. The old one will have taken on a 'set' from having been sitting. It is good practice to replace your impeller at least once every two years anyway, regardless of use.<br />If you run the old one, you risk having it come apart and clog other parts of the cooling system, as well as risking an overheat.<br /><br />Water is supposed to come gushing out of the large hole in the exhaust housing (leg) on the back of the engine, a little ways down from the powerhead. It will only do this once it's warmed up a bit and the thermostat opens. There is no tell-tale as such. Water goes in on the other side of the exhaust, facing the propeller. 'Muffs' do not fit your engine well, try to use a barrel filled past the seam between the lower unit and the exhaust housing.<br /><br />PS - whenever starting a new topic here, be sure to include your model number, year, hp. Not everyone knows you have a '64 60hp Johnson.
<br /><br />I hope this helps!<br /><br />PPS - I thought I referenced Joe Reeves post about the carb needle valves in your last post, and the post before that some time ago. Do you need help understanding his instructions?
