Dont let a good thing fool ya!
Realgun
Looks good now look-<br />
<br />Removed the wood and exposed the foam under the seat-<br />
<br /><br />Foam is above the deck and under seats should be dry right?<br />Look again-
<br /><br />on the shovel you will see water being squeezed out and the wood floor is getting rot. And is wet as all get out.<br /><br />And to think I was actually going to leve the rear area alone!. The floor did not flex much. But the straight edge showed that it was bowed about 1/2 inch in the middle so I thought I would take a look.
Rmac
Re: Dont let a good thing fool ya!
Wow,, just finishing up my 89 bayliner , mine was nothing like that, I replaced from the gas tank forward, all I have left is to apply the Ultra Tuff and is water time
Realgun
Rmac, I was going to leave this area alos but even though the floor seemed solid oce I cut across the floor in front of the seats I saw the water issues.<br /><br />The wood above the floor is very good but about 1 to 2 iches on the bottom is rotting. The area where the bildge is is gone. The stringers though are in good shape. Luck the transom is holding steady also.
