doral sucks
- Joined
- May 6, 2011
- 19
Lets hear about all the problems you have with your Doral boats. Maybe others will use this knowledge to find better boats.
We have a 2005 Doral elegante with merc 496 engines and bravo 3 drives that we bought new and nothing has been modified.
We are currently ingesting water in the engines because doral incorrectly install the exhaust to only 13 inches above the waterline instead of the required 15inches.
We have had to rebuild a bravo 3 drive that failed while driving 25 mph in a straight line.
We had a battery isolater smolder and catch fire under the gen. again factory installed.
We have a shower sump that never shuts off until you fix the float switch.
We have numerous loose and stripped interior cabinet fixtures.
Our cockpit cover never fit right.
Broken fuel gauges.
A fluid leak in the trim tabs.
Needed new seals in the head. lost suction
All of this in just over 100 hours of use!!!!!!
And Doral customer support is a joke. Martin Lalonde is who you call when you want to be even more disgusted.
I could go on, but I will let someone else have a turn.
Broken fuel gauges.
