Double-checking ignition tests - 77 85hp
iwombat
Well I had no/weak intermittent spark on #3. This motor has the single power-pack.
Took out all the plugs and performed the following tests.
1)swapped wires from power pack to coil between #3 and #1. #1 Didn't fire and #3 did. Problem doesn't appear in the coil.
Put the wires back to normal.
2) Swap #2 and #4 feeds from timer base with #1 and #3 feeds. Problem moves to #4.
Put wires back to normal.
3) Reset the air gap on the timer base using the proper tool. Now get a better intermittent spark on #3 but still not good.
Seems like a timer base to me, but before I drop $250 I'm tossing it out to the group-mind for comments.
iwombat
Re: Double-checking ignition tests - 77 85hp
Well, I went to go double-check the air gap settings and found that my flywheel wasn't seated properly when I torqued it down - d'oh!
Fortunately, I had another key handy. Fires on all cylinders just fine now.
I'm wondering now, if I should just replace the timer base at the end of the season. Do these things go out of adjustment often? It seems like something that shouldn't really happen.
iwombat
Took it out on the lake today.
5.5k WOT RPM and 38mph on the GPS. Runs better than it ever has.
I think that must've been the source of my slowly deteriorating performance. I must have had weak or intermittent spark off the timer base all last season. I never could diagnose it until I got a multi-cylinder spark checker and I could see #3 miss in comparison to the other cylinders. Chalk one up to having the right tool.
