I was running on the lake and the engine stoped running suddenley I tried to start it back and it would not spin over
So I dropped my trolling motor and fished for a couple hours and tried to start it again and it cranked but no power. Broke the engine down and found one badley burned piston and one gaulded piston on the same side. Also decided to check out a soft spot in the floor and did not turn out good, rotten to the stringers.:grumpy:To try to shorten this up. The boat is a 1977 TERRY AFB 15 and I like it so the boat will be restored. I am a mechanic that has very little knowledge on outboard engines. What concerns me is if i rebuild the engine what made it burn the pistons on the same side? reeds look good and carbs are good.
