Speakrdude
Ensign
- Joined
- Feb 25, 2004
- 942
Am in the disassembly process of 2 Bravo III's clean some corrosion, new steering pins, etc., When I noticed the 2 limit blocks on the trim rams shaft.
The Diagram shows the blocks installed with the large areas opposite each other. The way I found them is with the large areas facing each other.
Which is correct?
Which is correct?
