Downrigger on engine deck?
60thjeep
Can I mount a downrigger the the back engine deck? Will it be strong enough to hold? It's a Glastron 205.
Mark_VTfisherman
Re: Downrigger on engine deck?
I am not sure exactly where you mean but if you use a backing plate it should be good. If the deck is strong enough to walk on it should be able to hold the downrigger OK.
ebry710
Ensign
You also have to be able to turn it to store and if it is a manual downrigger, you need to be able to easily reel it back in.
