I have a 1996 Chris with dual Volvo Penta (OMC) 7.4GI (Model 74FFPNCA) with DP Outdrives (Model 3868443). These drives have had shifting issues since we purchased the boat 7 years ago. Immediately after purchase, we had to have the drives completely serviced and the issue was that the clutch cones were stocking and not shifting smoothly. (Turns out the previous owner hadn't had the drives serviced in a long time, and had barely used the boat for the previous 5 years or so.
That fixed the problem (for the most part), but they have always had a bit of an issue sticking in gear (hard to find neutral), which is a pain when docking the boat.
Yesterday, as I was docking the boat, the Starboard side quit shifting completely, stuck in neutral (Better than in gear when trying to dock!). Was worried that the shift cables were just way out of whack. Well, today pulled the covers off the back of the drives and verified that the shifting is happening, just not changing gears in the boat.
I've never pulled one of these apart, and am trying to determine best coarse of action. I understand the mechanics involved in the shifting process with the outdrive, so I'm wondering if the actual lever arm that moves the clutch cones may be broken.
Trying to figure what all I need. Trying to find a decent manual (When I put in the drive unit number,on the Volvo site, it gives different years, and doesn't indicate that it would be used with the 7.4s).
Any info would be greatly appreciated.
Thanks!
Thanks!
