Drain Bowls or Not Honda 90 4stroke ('01)
SteveRay
Winterizing for a friend of mine and I have read his manual and also a handful of threads here.
I stabilized fuel
going to run on muffs for 10-15 mins, shut down, change oil and gear oil, and fog cylinders. My question is whats the best thing to do drain the 4 carb bowls or not? AS the manual reads, the motor is self draining, correct?
I have ready many mixed reviews.
Boat will be stored indoors and unheated
robert graham
Re: Drain Bowls or Not Honda 90 4stroke ('01)
It's always a good idea to drain the carb bowls from time to time just to remove any water, debris or whatever. When I have my drain plugs out I pump the primer bulb to flush float bowl with fresh fuel, let drain, replace plugs, good to go! Great preventive maintenance!
SteveRay
Thanks for the quick reply.......Also I have a gear lube pump I use for my Alpha drive and I noticed that the manual calls for Quicksilver (Merc) gear lube....Is it safe to assume my Merc gear lube pump will work?
Also I imagine it is the same procedure to refill.....fill from the bottom until gear lube comes out the top hole ?
TOHATSU GURU
Self draining refers to the cooling system, not the carbs.
gss036
I doubt the the Mercury oil pump will work on the Honda, metric vs standard threads. I bought an adapter for my Honda, now use it on the Yamaha.
SteveRay
Right...I was referring to the cooling...I read the manual and see the outline where you start with bowl/carb number 4 and move the hose from one carb to the next
