Re: drain fuel tank
Disconnect the fuel line from the engine at the fuel pump, or at the quick connect fitting.<br /><br />Hang the line over the back of the boat, into a gas can.<br />Squeeze the primer bulb to get it going.<br />Once started, it will syphon the gas out.<br /><br />This will be a gravity syphon, and will go slow.<br />The end of the hose has to be lower than the bottom of the boat.<br />If your hose is too short, splice on another couple of feet.
