I noticed today the top screw on the aluminum drain plug collar was installed very crooked to where you could see the threads thru the drain hole - wasn't securing anything. I decided to remove the screws, get things cleaned up and installed correctly. I have a couple questions after removing the collar:
1. because the top screw was installed crooked, can I fill the old screw holes (if so, with what?), rotate the collar roughly 1/4 turn and drill new pilot holes and install new SS screws?
2. in the photo, is this a special gasket (it looks like it is manufactured) or do I just use some type of silicone sealant?
Oh yea, it is on a 2004 Tahoe Q4 F/S
Thanks!!
Thanks!!
