Re: Drain plug question
Maybe the prev. owner was plugging the wrong hole. Either way, I'll keep the bottom one plugged up!
Not likely, as you have a couple minutes at best before it takes on too much water to float... Are you trying to plug the hole from the inside or the outside? I've owned boats with both, it just depends on how easy the bilge is to get to from the inside. (which i kind of prefer, zero chance of some random piece of rope/line/seaweed/person opening it up from the outside that way)
Also, you don't want to keep it entirely plugged up. The absolute best practice is to pull the plug immediately after loading, and install it immediately before unloading. If the boat is on the trailer the plug is out. This helps the boat dry out, as well as reduces the chance of rainwater filling up inside the boat.
(yes, i know, this topic is a virtual holy war of the leave-it-in guys vs the take-the-plug-out camp. Obviously i'm on the side of take the plug out, with a good mental checklist of always putting it back in.)
