drain plug question
siego99344
I tried some drain plugs and they dont fit what size do you guys suggest that would fit this hole?
Ayuh,.... Looks like 1/2" pipe thread,.....
bruceb58
By the way, you better replace that screw with sealant or it will allow water intrusion into your transom if it hasn't already occurred.
siego99344
no it hasn't boat hasn't seen water since I've had to been replacing parts like crazy.... and 1/2 you say ok thats next on my list
siego99344
but isnt a 1/2 to small I just tested a bolt thats 7/8 and it kind of screws in but didnt go in all the way.
Georgesalmon
!/2" pipe is 1/2" on the inside. The outside where the thread is, is almost 3/4". So looks like 1/2" PIPE is the size you need.
treyc82
My local WalMart sells a two pack of Marine Brass Garboard Plugs. Like someone posted above, it looks like you need a 1/2" NPT which would measure 0.840" (OD of male threads).
http://www.ebay.com/itm/Brass-Garbo..._Accessories_Gear&hash=item2ed159aa09&vxp=mtr
http://www.amazon.com/Invincible-Ma...45&sr=8-2&keywords=Marine+Brass+Garboard+Plug
http://www.walmart.com/ip/Attwood-Bronze-Garboard-Drain-Plug/16350988#Product+Reviews <-- (This link is not for the flange and plug, it is just for purchasing the plug.
siego99344
by golly it was 1/2 does it have to screw all the way in? I screwed it in and it screwed half way in not all the way is that safe?
bruceb58
Yep...that's fine. I would use a brass one. You can get them at Lowes or HD.
