Re: Drain Plug
If I use a regular brass plug, what should I use on the threads? Just regular Teflon tape?
Ayuh,.... I use Nothin'....
I boat in sweetwater, I take the brass plugs outa the block, 'n manifolds in the Fall, 'n drop 'em onto the intake manifold...
In the Spring,....
I take 'em off the intake, 'n screw 'em back into where they go,... Just snugged with a 9/16" end wrench,..
I've never had, nor seen any leakage issues, ever, at All....
I here Saltwater Boater's will coat 'em with teflon
paste, when pullin' 'em in the Fall for drainin'....
They put 'em back in for winter strorage to preserve the threads in the cast iron,... Less chance of Rust....
Perfect Seal, or Form-a-Gasket, #2 also works, just Fine....
