Drain raw water side after flushing?
longtravel
Should I be draining the raw water side of the motor after flushing it ? The boat is used in salt water. I have been draining it but I'm not sure if it is the right thing to do.
Bt Doctur
Re: 496, Drain raw water side after flushing?
No need to, dry cast iron rusts faster than wet cast iron.If you were in a slip you could always flush it with fresh water either thru muffs underwater or rig up a hose system with some valves.
