Drain Valves
hhornig
I have been told that I can replace my drain plugs on my Mercruiser V-6 with petcocks which will allow me to perform the task easier. The petcock should have a large enough hole through it so I can run a wire into the block to remove the sluge if present. Does anyone know of where I can get such a valve?
RogersJetboat454
Re: Drain Valves
Right here...; http://www.iboats.com/1-4-Drain-Tap...1919033--**********.121931361--view_id.485719
The tip can be pulled out in case you need to de-muck the drain hole.
