brivander
- Joined
- Apr 16, 2011
- 69
In my 92' four winns 221 lib -- when I get water in the cuddy, it doesn't drain back to the rear bilge so I can drain it out of the boat even if it's higher than the drain hole, what do you think, a clog? What's going on?
The center of the floor does pull out if the rear seat is out of it...which I should have thought about sooner since it was just out for service. I always just assumed the gas tanks were there and the front should drain through there and into the rear.
It's got me worried I may just be dumping water under the floor for some reason, this would not be good. Because if no more is going in, and nothing is coming out...it may be full...
So what connects the two, a hose? and where does it run?
Help...
Help...
