Draining carb bowls
Frank115
I was wondering if it was possible to drain the carb bowls on my 1979 115 I6 without taking them apart. I looked for plugs to open but did not see any.I want to get all the gas out of them for storage.Any tricks for this.Thanks again for the help you guys are great.
emckelvy
Re: Draining carb bowls
At the bottom front of each carb there is a brass main jet plug.
Place a couple of paper towels or shop rags under the carb to catch the drainage.
Remove the plug with a 7/16" wrench, tilt the motor up a bit, and virtually all the fuel will drain out of the carb.
There's a fiber gasket under each plug; make sure the gasket stays in place and tighten down the plug after draining.
That should do it! HTH..........ed
Silvertip
Letting an engine run out of fuel means all cylinders don't run out at exactly the same time. No fuel means no lubrication. Draining the carbs also means oil residue and air are present which means the carb is prone to gum and varnish build up. Treat the fuel, run the engine long enough to make sure the carbs have treated fuel in them. Fog the engine, change the lower unit lub and you are good for at least six months of storage.
