Im trying to understand your post........
If the boat was winterized with antifreeze and the drain plugs are in, manifold and block.
Put the boat in the water and just go!
The water from the bay, river or what have you ,will mix and flush the antifreeze
out along with the cooling water......
It was winterized with antifreeze in it. I found the two drains on the manifolds and the 2 on the block. is there a valve or anything between the motor and the drive? does the drive have a drain?
