Re: Draining Live Well
Neverhome: No pipe in the center to pull for it to drain.
Craig: I have the bait well that's located on the port side just aft of the passenger sliding seat.
The live well I'm referring to is located on the starboard side next to the engine. It has an inlet that pumps water in but nothing to drain it
. The P.O. mentioned that he had to physically scoop the water out of the well
. If necessary, I'll install a drain with plug that will drain in the bilges then run the bilge pump to empty the bilge
