1988 Baretta bow rider and I need to drain about 1/2 a tank of old fuel. I tried to create a siphon (before I knew about the anti-siphon valve) and have tried to pressurize the tank via the vent, but cannot get the fuel out. I used a vacuum pump with a small reservoir and that works, but will take me a month to get the fuel out. Aside from using an electric fuel pump from a car fuel tank or some manual pump device or pulling the sender cover and putting some hose in there (probably won't get all the fuel) is there any other simple way to get the fuel out?
Also...is there any reason I wouldn't want to use a fuel primer bulb on an I/O boat like this to ensure that the fuel pump can get fuel after the boat has sat for a while?
thanks
thanks
