Re: drilling exhaust hole in leg
It's interesting that you are considering drilling into your exhaust housing because the '56 10 hp 'rude that I picked up at an outboard boneyard has an access plate in the starboard side of the housing in order to reach the shift rod connector. On this particular motor, I noticed the plate had three holes drilled in it, but I thought that might be normal for this motor. When I finally got the motor functioning and started up, I found out that the three holes in the plate were exhaust relief above the water line. I also discovered, once I put the motor onto a boat and was able to crank it up to cruising speed, it was pretty damn noisy for a small motor, and I found that the source of the noise was those three holes in the access plate. Also, this motor is particularly strong, and I don't know if the exhaust relief may have an effect on its power. Maybe, if your motor has a similar access plate, you could save yourself from having to drill into the exhaust housing itself.
