Found a drip in my bilge today. It's coming from a drain on block. Looks like it is leaking at where the fitting connects to the block itself. Would like to take fitting out and replace if I can or at least put some sealant around the threads or something. My concern is...if I take this fitting out is the bilge going to fill up with a ton of water? The boat is in the water.
