76SeaRay
- Joined
- Aug 24, 2017
- 1,071
So, just got back my upper housing, bell housing, gimbal ring and gimbal housing back from media blast. My lower housing a a new Mercruiser so painting not needed and my transom plate was in great shape without any corrosion so doesn't need paint either. To paint the blasted parts, I will be using 1) aluma prep, 2) alodine, 3) DP90 epoxy primer, and then 4) PPG finish coat to paint them. I have of course pitting in areas that had some corrosion. What is the best filler to use to smooth the pitted areas before paint? Also, would the filler go directly on the blasted surface followed by the above sequence to paint or should it go on after aluma prep and before alodine, after alodine and before primer, or after primer and before finish coat?
Thanks....
Thanks....
