ziggy
- Joined
- Jun 30, 2004
- 7,473
which way to go. should i pull my drive and have a look + split the halfs and inspect the impeller? engine and drive listed below. i just got the boat last fall. the dealer i got the boat from in SD said he replaced the impeller prior to sale. had no over heat issues and feel i can 'probably' believe this dealer. had dealer here pull drive and inspect bellows and gimble brg. , ujoint, alignment after i got it last fall. all looked good at that point. put maybe 20 hours on it prior to winterizatin. did R&R drive fluid at end of last year. was nice and clean. though did put another hour ontoit after the change on a nice day. put to sleep that way for winter. i feel the proper thing to do would be to inspect both. which i should have done at end of season last year. but i was ambivlant last fall and didn't. or should i just splash it with the minor use it's had after the inspections i've had? which way to go....
