scutly
- Joined
- Aug 20, 2009
- 368
as part of my first winterization i built a drive stand and pulled my drive to store in my garage. i spent today cleaning, sanding and anti-foul painting it. replaced my anodes too. tomorrow im gonna do my first install. got my gasket and o-rings all set. scored an engine alignment tool from eBay and have read the manual three times. but i have two concerns. i copied this from the manual.
"IMPORTANT: Rubber gasket must be properly positioned and glued in bell housing bore before installing drive unit or water may leak into boat. Ensure that rubber gasket and water passage O-ring are properly positioned in bell housing."
my first concern is what glue to use? bellows adhesive? it didn't seem like the old round rubber gasket was glued in the bellows. it sorta was just sittin in there. ok, my second concern.
"Snap the Shift Slide Stabilizer Tool onto stud directly below shift slide and position as shown."
can the install be accomplished without this tool? or am i running out in the morning to find one? any other pointers?
thanx in advance!
thanx in advance!
