Hi All, as title says my low-hour 2001 4.3L Alpha 1 combo is slipping under load, and seems to be getting worse. Under load the rpms will suddenly spin-up 200-300 with no boat speed change. Feels exactly like prop cavitation from weeds, but prop is clean.
I have two questions:
1) Can this be from an improperly adjusted shift cable?
2) Can I somehow mark the primary drive shaft at the engine coupler to check for coupler slip? I have a rear inspection plat at my transom that allows me to see and access the drive shaft right as it exits the bellhousing.
Here are other clues:
- If first noticed right after a lower unit service, new water pump, bellows job, new final shift cable, new tilt senders. (but not positive could've started before service and I just assumed it was weeds).
- No noise or clunking or grinding that I can hear
- I've marked the prop and prop drive shaft and no evidence of spun prop
- Happens under load, higher speeds, tubing, more passengers etc
- Has quickly gotten worse over a few outings
- No evidence of rubber or aluminum shavings near bell housing at back of engine
- I believe this is a newer/rebuilt engine, engine sparkly clean, and I found pieces of broken oil pan, and a half of a broken rod cap in bilge. Hours meters says 200.
- Engine starts and runs very well, no over heating or anything (yet), good compression, oil pressure etc.
