Drive lube fill
umtnman
What is the proper way to fill a 1989 omc cobra out drive? I changed it last weekend and after runnung it it has a lot of air in the oil?
Thanks
Re: Drive lube fill
Ayuh,.. So,.. How did You fill it.... Pumped in from the drain plug,..??
umtnman
Re: Drive lube fill
no, I think this is where i messed up. Filled it from the check plug( just pored it in). oops
Juniinc
Re: Drive lube fill
pump slowly into the lower drain hole or in the middle.
