Drive pin 1972 25 hp evinrude
jethro66
Hey guys wats up, I tested my motor in the tank and noticed my motor does not shift in gear. shut it off and noticed my drivepin broke in the tank. i replaced it before but I fabricated it . the dealer told me he did not have one so grind it down. I noticed that when I twist the tiller theres water coming out where it joins to the motor is this normal? why would the pin brake? It jumps out of gear sometimes
jethro66
Re: Drive pin 1972 25 hp evinrude
yes sorry shear pin its a bigger pin that was grinded
Paul Moir
Jumping out of gear will do it, since sometimes it's followed by quickly jumping into gear.
Make sure you've got the right material, etc, for the pin. It needs to be stainless steel, 3/16" diameter 1-1/16 long.
papasage
is that same as shear pin . ? the one that is through the prop . may be the mettle is to soft . or shifting gears at a high idle . don`t shift slow push quick so it wan`t chatter
jethro66
theres no load its in a test tank. I think the shaft is a little wobbly. why is there water coming out of the side were the tiller meets the teeth underneath?
Paul Moir
Oh, sorry about that. That's not supposed to be happening. Pop the cover and look around for a leak. Base of the powerhead, the head gasket, thermostat housing gasket, and exhaust cover gasket are likely culprits.
F_R
Sure, there's a load in a test tank. If it's jumping out of gera in there, it will Really jump out of gear on a boat. You got some worn out parts problems. As someone said, jumping out of gear and back in will snap the drive pin after just a few times. It's very common.
jethro66
theres a hole there and exhast is coming out I take a look
