Re: Drive shaft boot hole
This job can be easy or hard, depending on the level of corrosion present, for the most part.
For example, the first step is to remove the outdrive. It'd be easy for me, because I've had it off recently. Some are very difficult to remove.
The next step is to remove the bell housing..this means removing the shift cable (Make up a tool to remove the nut out of 3 deep sockets welded together...do you have a welder?...or buy one I guess) hinge pins on either side of it. Sometimes the hinge pins are easy, sometimes they are brutal.
Then disconnect the clamps that hold the drive bellows, water pipe, and exhaust bellows. Pretty easy. Disconnect the engine side of the drive bellows. Pretty easy.
Now, pull the gimbal bearing with a slide hammer...and replace the ujoints on the drive input shaft. My advice is to use the best parts you can find. Sierra stuff worked ok for me so far.
Install a new gimbal bearing with a driving tool. I made one from a 4X4, but you can buy the right tool.
CHECK ALLIGNMENT. Please. You need an allignment tool, but it's something you should have anyway.
Now, the fun part. Get some bellows adheisive and slather it on the engine side of the drive bellows and clamp it up.
The hard part is to now do the other end (Bell housing end). You have to get the adhiesive on (Don't worry if it skins up, it is actually supposed to do this) and then tighten up the clamp on the bell housing nd. Trust me, it sound easier than it is. It IS doable though.
Then assemble in the reverse order from there. You will likely have to adjust the shift cable (Because you disturbed it) which is sometimes tough as well.
Hope that description helps.
Chay
