I have a 1979 15hp Johnson. I was changing out the waterpump. As I was removing the impeller, I noticed the drive shaft coming up with it. Is this suppose to do this and can I remove the drive shaft this way without a lot of problem reinstalling it. Looking at parts breakdown looks like a chance of a spring and ball beaing dropping down in to propshaft housing.. The reason I ask this is the seal below the driveshaft is in bad shape and needs to be changed. The spring on seal is broken. Will I need special tools to do this?
